× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EAX80 and BT Smarthub2 Issues
PStafford
Follower
Hi
I have full fibre BT broadband through a BT SmartHub2 router along with three BT wifi discs.
My Nighthawk AX8 wi-fi extender seems to drop wifi connection regularly and even clash with the wifi itself. I noticed my iMac ethernetted to the router was refreshing its IP address continuously until I switched the AX8 off.
Smart set up is off (on both router and AX8).
Any suggestions please?
Message 1 of 2
Guru
Re: EAX80 and BT Smarthub2 Issues
Try powering off the BT wifi discs and see if the EAX stays stable. If they're setup in mesh, the extender can be hopping around from router to mesh discs and it causes problems.
It isn't recommended to mix mesh systems.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 298 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
