× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX2700 Password Issues
98joscro
Follower
Hi,
Having issues setting up this wifi extender. When I connect to the network it asks for a password I have tried the default "password" and it doesn't work. I have tried getting on to mywifiext page when connected to the _EXT network but I cannot without entering a password. I can only access this page when on the normal wifi network I get the message:
You are not connected to your extender's WiFi network.
I don't remember choosing a password, how do I proceed?
Model: EX2700|N300 WiFi Range Extender Essentials Edition
Message 1 of 2
Guru
Re: EX2700 Password Issues
Did you set it up using wps?
If so, try factory resetting the extender (push and hold reset for 7-15 seconds while powered on).
then use the installation assistant for setup and not wps.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 379 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
