lorialloyd's avatar
lorialloyd
Follower
Jan 06, 2016
EX2700 lost password
I have forgotten/lost my password. Is there a way to look it up to avoid having to default back to factory settings and starting over?
1 Reply
  • Babylon5's avatar
    Babylon5
    NETGEAR Employee Retired
    If you mean the Admin password then unfortunately not, a factory reset will be needed. If you trust the people in your house then you could write it on a sticky label to put on the bottom of the extender.
