×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
EX2700 not using DHCP reservations
jpullam
Guide
My network now contains the following 3 devices:
1 - ConnectionHub that acts as a fibre modem and router and does the DHCP function for the local network, including IP address reservation.
2 - WN203 Access Point that provides the wireless capability.
3 - EX2700 Extender to extend the wireless network
This appears to work fine for most devices until DHCP reservation is required. The EX2700 appears to create new IP addresses for devices that are previously known to the ConnectionHub/WN203 and are already in its tables, and it does not use the pre-assigned IP addresses that are needed for some devices. This is not a problem with the WN203 on its own--the DHCP function works correctly and it assigns reserved addresses correctly.
Message 1 of 4
jpullam
Guide
Re: EX2700 not using DHCP reservations
I'm disappointed that I've put the time and energy in configuring this wireless and can't get it to work properly. Does this device support the upstream DHCP addresses at all? Is this something I've done wrong? Would it support the DHCP assignments if I remove the WN203 and just let the EX2700 talk directly to the ConnectionHub's network after turning its wireless back on?
Message 2 of 4
DarrenM
Sr. NETGEAR Moderator
Hello jpullam
Are you on the latest firmware version .22 addressed a issue with DHCP changing.
DarrenM
Message 3 of 4
jpullam
Guide
I don't know where your version number comes from, but mine says Firmware Version: V1.0.1.10 and that's a very recent download that I did from the Netgear site last week.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2530 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
