Melody1230's avatar
Melody1230
Follower
Oct 06, 2017
EX2700 with google wifi router
Is it possible to use ex2700 with google wifi router in any way? I'm currently using google wifi router, but since my room is a little further away, my speed is really slow compare to my apartmentmate who lives there, so I want to set this ex2700 up, but it doesn't have WPS..any way to do it ?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Melody1230
    If the ex2700 can connect to the wireless network you should be able to do the setup without WPS.
    DarrenM
