- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX2700 won't connect with mywifiext.net
- Mark as New
- Bookmark
- Subscribe
- Permalink
Bought a new router and trying to set up my EX2700 extender for the new router...WPS will not connect, so I performed a factory reset and it shows up on my list of available networks. I connect to NETGEAR_EXT and the "device" light goes green showing the EX2700 is connected to my computer. However, when I then try to go to www.mywifiext.net, it tells me it's not connected to my computer. But, both the computer and the extender are acknowledging that they are connected to each other. HELP!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX2700 won't connect with mywifiext.net
And, I've tried connecting to the extender's IP Address...no luck. So, since I cannot connect to the IP Address or mywifiext.net, I cannot upgrade the firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello JC4067,
Have you tried setting up your extender with a different device? If you a have a laptop or mobile phone you can use, that would be worth a try.
~Christian
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
