MyRangeExtend's avatar
Aug 28, 2020
EX3110 – AC750 Dual Band WiFi Range Extender compatible with Zyxel Router?
Are the EX3110 – AC750 Dual Band WiFi Range Extender compatible with Zyxel Router?
1 Reply
  • plemans's avatar
    Most extenders are compatible. But not all can be installed using wps. In those cases, you using the installation assistant
