× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
EX3700 Cannot Update Firmware
Enzuigiri
Initiate
Hi, can anyone assist me with the update of firmware for the EX3700?
I have seen many people have issues before, and I am finally getting round to it now as well out of date, but cannot update as the extender returns that the firmware file is invalid.
I have done the usual stuff of downloading the zip from netgear, unzipping so that I have the .chk file available but the extender doesn't like it no matter which release I use.
I have looked at solutions online but nothing works so if anyone knows what the fix is I would be grateful otherwise this will have to go in the bin for an alternative brand as armour reports huge security flaws
Thanks in advance
#ex3700
Message 1 of 4
Accepted Solutions
Enzuigiri
Initiate
Re: EX3700 Cannot Update Firmware
I have resolved the issue myself.  It turns out that if you go into the Netgear support site and look up your device (EX3700) it suggests that the firmware is a .chk file.  The documentation also says this is correct.
However, if you login to my netgear and click on your product the download is an .img file which works - just a bad support site I guess.
Message 3 of 4
All Replies
Guru
what firmware version are you on?
You can use the snipping tool to take a video of what you're doing. Thats sometimes faster and allows us to see whats happening/going wrong.
Message 2 of 4
Enzuigiri
Initiate
Message 3 of 4
Guru
glad you got it working. Its usually either a .img or .chk
either work
Message 4 of 4
Discussion stats
  • 3 replies
  • 1015 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
