× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX6100 reset trouble
tevans84025
Follower
I have reset the extender to factory reset to connect to a new WiFi router. When I go into connect to Netgear.ext to setup the selection is not there - only the 2Gext and 5Gext are there and neither of those will connect or bring up the netgear setup page in browser
Model: EX6100|AC750 Dual Band WiFi Range Extender
Message 1 of 2
Guru
Re: EX6100 reset trouble
It might not of fully reset. push and hold reset for 7-15 seconds while its fully powered on.
If that doesn't work, you could always hardwire into the extender with a pc/laptop for setup.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 895 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
