- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX6120 constantly losing internet connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX6120 constantly losing internet connection
If the resetting doesn't work, try troubleshooting, and then if that doesn't work you can downgrade firmware.
Everything worked great prior to the update? Try the troubleshooting for extenders at the link provided. Maybe the firmware update changed what wifi channel you used and that one has interference. Or some other change caused a problem.
https://kb.netgear.com/25731/Troubleshooting-NETGEAR-WiFi-Range-Extenders
If that doesn't help at all you can downgrade your firmware. The link at the bottom will have the download link to get firmware. Where the current version is, there's a +view previous versions. This will have the older firmware. Follow the manual update procedure and use the older firmware. If at all possible do it over a hardwired connection. After the downgrade, reset the extender again. Then go through your setup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
