CI's avatar
CI
Follower
Mar 03, 2018
EX7000 Extender
Can I use the extender as a router? Hooking it up straight to the cable modem.
1 Reply
  • Hi CI,
                 If you cable modem has a NAT and DHCP server, you can setup the extender as AP and use it. Else, it is not a right choice and you need to go with a wireless router.
