- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX7300 On Light working only
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am running Windows 10 Pro ver 20H2. My router is the Nighthawk AX12 (RAX120). I am using the Netgear extender EX7300. I attempted to update the extender with the latest firmware after receiving an email notification from Netgear. The firmware did not work. As a matter of fact, the extender’s router link, client link, and WPS turned off. I received the message, “You are not connected to your extender's Wi-Fi network on the internet. In Windows I checked my Network status and it displays only an Ethernet Private network. Under the heading of “change adapter options, it only list the Ethernet Network Realtek PCIe GbE Family controller. When I log into my Router online at routerlogin.net, I can see the extender listed under Access Control as a device allowed but not currently connected to the network. This section only gives MAC addresses. The only good thing is the “On” light still works. Whenever I unplug the extender and plug it back into the wall outlet, I can turn the extender off. When I turn the extender on, all the lights come on for just a second. The on light changes from amber to green. The remaining three lights, Router link, Client link and WPS lights remained off.
I have done about three factory resets, plug into the wall, unplug from the wall several times. I have used an Ethernet cable to access the extender. The results of that action is that it turns on the WPS. After I unplug the Ethernet cable from the extender and turn on the EX7300, still no router link, client link, and the WPS blinks for about a minute and it turns off.
Since I have given more than enough money to Netgear over the years for their routers, I am not about to pay for premium service. I am hoping that in the “Season of Giving” than someone out there can give some free advice on how I can turn my extender back on to start working again. I hope that I have given all the information that is needed. Thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX7300 On Light working only
you can try recoving it via tftp.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
- Mark as New
- Bookmark
- Subscribe
- Permalink
I plug an ethernet cable from my desktop to my extender EX7300 and I followed the guideline for the tftp firmware upload twice with no success. The video shows the guy downloading tftp2.exe. I am not sure where he got that from. I followed the guidelines to activate windows 10 tftp before trying to flash the extender. It still did not work. The second suggestion is a few levels over my head.
nmrpflash. I wasn't sure which of the nmrpflash I should use or how to use it. for example: nmrpflash.dev, nmrpflash.manifest, and nmrpflash.rc.. If possible would you explain a little simpler. Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
follow the netgear guide. The video is just the basics of how to do it.
you can also try nmrpflash
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Netgear guide was not helpful. Are there any other suggestions, that my help me solve this problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Where is it failing in the process when using tftp/nmrpflash?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is failing at the start of the process. The Router Link LED and the Client Link LED never come on anymore after I attempted to update the Firmware, EX7300V1-EX6400V1-V1.0.2.152.img on Dec 31st. Only the "ON" light turns on now. I have tried connecting the Extender to my PC using an Ethernet cable but it will only turn on the WPS. Once I disconnect the cable from my PC the WPS turns off.
I purchased this Extender new, June 26, 2020. The Extender is currently taking up space on a wall outlet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If its new as of june 2020, then you should still be within your warranty period. you can start the rma process.
Click on "mynetgear" on the top. Register an account and the device. From there you can start the process.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I registered the Ex7300 June 26, 2020 in my Netgear profile. All standard Warranties including hardware, phone support, email support, chat support, power supply and accessories have expired. I will not pay for an additional warranty contract for this Extender.
- Mark as New
- Bookmark
- Subscribe
- Permalink
if its refurbished/renewed/used, then you'll have a shorter warranty period. If it was new, it might be worth investigating why the warranty is expired.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, I will contact Netgear about the warranty expiration.
