jamieblack78
Jul 10, 2017Aspirant
EX7300 Wifi Extender
Hi, we use the above product in a domain environment and it does as we require however we have noticed a few problems and require some support.
WI-FI devices drop connection every so often although within acceptable range of the extender. we also noticed the DHCP server was getting constant BAD_ADDRESS errors so we looked into it further for some reason the extender seems to have every ip address and every time a client connects there is an ip conflict because the extender already has that ip. the extender is also constantly sending out ARP broadcasts for the default gateway.
Any Ideas?
- jamieblack78Aspirant
----UPDATE----
it seems to be only apple devices that are affected.
Apple_xx:xx:xx Broadcast ARP 42 Who has 192.168.1.25? Tell 0.0.0.0
Apple_xx:xx:xx Broadcast ARP 42 Gratuitous ARP for 192.168.1.25 (Request)
xx:xx:xx:xx:xx:xx Broadcast ARP 42 Gratuitous ARP for 192.168.1.25 (Request) (duplicate use of 192.168.1.25 detected!)
It repeats this process over and over changing the ip by one each time.
- DarrenMSr. NETGEAR Moderator
Hello Jamieblack78
Have you tried to assign a static Ip to these devices?
DarrenM
- jamieblack78AspirantYes still the same result they just hang for a good 10min before accepting the ip address
