RAB99
Jun 16, 2021Follower
EX7700 Extender is slow when using ethernet connection
I've had the EX7700 extender set up in conjunction with a BT broadband hub. Via the Netgear hub manager I can see connection to the 2.4GHZ and 5GHZ channels both of which seem to be used for wireless devices successfully. I've now tried for the first time to connect a device via ethernet wired connection to Netgear.
Normally when connected directly to the main router this device will obtain download speeds of >40MB/sec. However now when connected via the extender this device only achieves less that 10MB/sec.
Should the superfast web connectivity be available via the extender? If so what Netgear settings do I need to change? (Don't have built-in wireless in this device (PC) to check that performance via the extender.
Thanks for any feedback & suggestions.
No RepliesBe the first to reply
