× Some paid Circle Parental controls customers may be showing free options only. Router firmware correcting this issue will be available ASAP. Visit Status.NETGEAR.com for updates.
Discussion stats
  • 4 replies
  • 150 views
  • 0 kudos
  • 3 in conversation
Announcements
Top Contributors
Reply
Highlighted
EX7700 Fastlane option not available?
I just purchased the EX7700 and when setting it up I noticed that in the menu I don't have the option to use FastLane connect.  Is there something I am missing here?
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router, EX7700|AC2200 Nighthawk X6 Tri-Band WiFi Mesh Extender
Message 1 of 5
Highlighted
Guru
Re: EX7700 Fastlane option not available?
How did you setup it up?
wps/installation wizard?
Something to keep in mind is that the EX7700 is a tri-band. If you're setting it up in extender mode, it reserves one of the 5ghz bands just for router---extender communication. its called fastlane 3 and works to reduce the throughput loss from using extenders.
CM1100->RAX200->GS716v2->RBR50->RBS50-RBS40V-RBS50Y
Message 2 of 5
Highlighted
I used the installation wizard as the WPS didn't seem to work.
I was referring to the below links that indicates under the 'Do more' menu option there is a way to select 'Fastlane' option.  However this option does not appear on the menu.
https://nighthawkmywifiext.net/netgear-nighthawk-x6-setup-netgear-ex7700/
https://kb.netgear.com/24662/What-is-FastLane-Technology-and-how-do-I-configure-it
Message 3 of 5
Highlighted
Guru
If you look at the fastlane article, thats for fastlane 2 devices. The article doesn't have the fastlane 3 devices (tri-bands) listed as applicable because they fastlane 3 devices function slightly differently.
Message 4 of 5
Highlighted
I am experiencing the same thing as everyone else.  This was not a problem a month ago, but it is no longer available.  Has Netgear advised?
Model: EX7700|AC2200 Nighthawk X6 Tri-Band WiFi Mesh Extender
Message 5 of 5
