Moshik's avatar
Moshik
Tutor
Dec 25, 2021
EX7700 setup lost after powering down the system
Hi,
Recently, with no fw update of any electricity unusual event, my EX7700 that I use as extender, loos its configuration and needs a wired laptop connectivity in order to setup again.
All front LEDs are off, when I connect the laptop ethernet cable, the Network LED light ON.
Is there a backup battery inside that needs replacement?
(I have the unit ~14 months)
Thanks
Moshik
  • There isn't a battery inside when you saved the configuration it is stored in the flash memory of your router so after powering down everything should be saved. Also to reset normally you should enter a sharp object in the reset punction hole. Even in the app you should need to click on reset. I would recommend to make a backup of your configuration and save it to your computer so you can restore it later on.
    • Moshik's avatar
      Moshik
      Tutor
      Thanks,
      But still cannot understand how resetting the unit can solve my issue?
      And how saving the configuration on my laptop can cause the unit to boot with my configuration?
      If the unit has a flash issue after one year, Netgear should do a recall for the problematic units.
      As an HW engineer, it seems that there is a faulty design/component.
      • nielsvds's avatar
        nielsvds
        Luminary
        What I wanted to say is make a backup of your current configuration so you can easily restore from when it happens again. So you don't have to configure it again.
        Did you already tried another outlet? Other reasons faulty power adaptor, overheating, hardware failure.
        Where you applying a configuration change?
    • Moshik's avatar
      Moshik
      Tutor
      I placed the recent one, and still have the “lost setup” issue
