× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
EX8000 Green power light flashing green.
resed
I replaced my firmware in January 2022 when instructed to do so and all was fine until 3 days ago.  The unit is off line and the NETGEAR_EXT wireless link does not show up on my iMac computer or iPhone 11 Pro.  I have followed the instructions of the Mac version in "How do I upload firmware to my NETGEAR router using TFTP on Apple macOS?" and have had no luck.  The instructions indicate that I should not press enter for the upload until I have turned the EX8000 power off for 10 seconds and then back on, but the expected green flashing power light turning to orange flashing does not happen and I get the terminal message that the firmware file on my desktop does not exist.  I have tried this multiple times all with the same result.
Any other suggestions out there?
Thank you!
Model: EX8000|AC3000 Nighthawk X6S Tri Band WiFi Mesh Extender
Message 1 of 3
Guru
Re: EX8000 Green power light flashing green.
did you start with a factory reset?
Push and hold reset for up to 30 seconds while powered on.
Then give it a few minutes. I've had it take a while to fully boot.
If that doesn't work and you can't get tftp to work, you can try nmrpflash.
https://github.com/jclehner/nmrpflash
Message 2 of 3
resed
Thank you.  I had not done the full 30 second reset in advance so I have started over and retried everything, starting from scratch. I still never get to a flashing orange power light and it still tells me the EX8000-V1.0.1.240.img file does not exist, even though it is sitting on the desktop and have entered the correct information into terminal to access it.
I took a look at the nmrpflash option and I am pretty new to terminal and am not confident enough to try it.  Also, you had a comment in the link that indicated what NETGEAR equipment it had worked on and the EX8000 was not listed.  I guess I am stuck at this point, but thank you for the help.
Message 3 of 3
Discussion stats
  • 2 replies
  • 1021 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
