- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Extender not showing on network list
- Mark as New
- Bookmark
- Subscribe
- Permalink
Right now the extender is located in the same room as the modem and router so I can get it working. The status symbol is green. The link rate is green and the WPS button is solid green.
I can't find anything that tells me what to do if the _EXT names does not appear.
Can anyone help me? Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Extender not showing on network list
ChristianS
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What firmware are you running on both the router and the extender?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes I have reset extender ect just comes back the same as it was . The funny thing is the connections my Router # shows , the 2Gext , and 5Gext shows up say on my laptop , cell phone , but do not show up on my PC . Only my router and G2ext show up on PC to connect to internet. the 5Gext on all my wifi devices shows all 3 but the 5Gext is open to anyone and is not secure.
I also pick up my next door nieghbours router on my PC.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure what you mean by firmware????
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Jimbo888,
Can you please clarify what issue you are experiencing?
You are able to see the router, the extender's 2ghz, the extender's 5ghz, on all your devices. On your PC, you can't see the 5ghz. Is that correct?
Is your PC capable of picking up 5ghz networks? or has it ever been capable of connecting to a 5ghz network?
If you are using the WN2000RPTv2, you can check your firmware by following page 24 of 33:
http://www.downloads.netgear.com/files/WN2000RPT_UM_05MAR2012.pdf
The most recent firmware version is also listed here:
http://support.netgear.com/product/WN2000RPTv2
Firmware is software that is loaded onto the hardware components of your NETGEAR router.
More on firmware: http://kb.netgear.com/app/answers/detail/a_id/23442/~/installing-the-latest-firmware-on-a-netgear-ro...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes it did show at one time on my PC at one time . 5Gext also does not show up on my network connections on Netgear Genie either, but does show up on mobile devices and it does work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Jimbo888,
Which router model are you using with the extender?
Please check if the router is Broadcasting its SSID.
Please also try to configure the 5ghz to different channels and modes.
Here is an example of a NETGEAR router settings page
- Mark as New
- Bookmark
- Subscribe
- Permalink
When I open netgear genie My wireless connections does not list 5Gext . So I cannot config. as your example shows . It only lists my Router , and 2Gext. I must say again everything works with my extender 6100, On any portable device it lists all 3 , my router SSID # , 2Gext , and 5Gext . They all work the only problem is the 5Ext is open and not secure. My PC does not list 5Ext as a connection option, and netgear genie does not list the 5Ext. Only my SSID # and 2 Gext.All I am trying to do is secure ther 5Gext.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, please confirm which router model you are using.
Can you also confirm which NETGEAR genie you are using? Is it the web browser version? (routerlogin.net) or is it the Genie app that you can download here.
You can also post a screenshot of what you are seeing in your settings.
Thanks
