Michele_Ita72
Aug 05, 2023Follower
Guest wifi network doesn’t work on EAX20
Hello
I have Netgear EAX18 as network extender. It is connected to my main router using wifi network.
I configured it to extend my home network but I need to create also a guest network to share only the internet connection with others devices or withr the guests.
The problem is that I am not able to access on both networks at the same time.
I mean, the Guest Network is visible on my wireless devices, but I can’t access on it.
The Guest network is accessible only if I disable the main network on the extender. Of course, in this case I can’t use the main network that is what I need.
See below snapshots:
Is this a limitation of this extender? Or is there some problem on my configuration or device?
Thanks in advance for any advice.
No RepliesBe the first to reply
