are2128
Jul 27, 2017Follower
How can I connect my booster to a different WiFi network?
the wifi my booster boosted was terrible so we got a new wifi network. I am trying to figure out how to connect my booster to this one now
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Are2128
You will need to factory reset the unit by holding the reset button for 10 seconds then you should be able to do set up again like it was new with the new router.DarrenM
