Captivator
Aug 01, 2019Follower
How to disable WPS
To disable WPS, simply hide SSDI in settings, this way the WPS function will be disabled.
There's no option in EX2700 that would allow you to disable WPS, so hide SSDI and U're all set.
1 Reply
- DarrenMSr. NETGEAR Moderator
Thanks for sharing your tip.
DarrenM
