sankeertana's avatar
sankeertana
Follower
May 01, 2017
How to reset WN3000RP V3
Hi I have WN 3000RPv3 extender which I am using without any issues with to extend my internet range. Now I bought a new 4g router and need to re configure this device to extend that new 4g router.
facing issues as listed below.
1. When accessing www.mywifiext.net page after connecting to the device which is publishing wires network of old AP, this page is seeking login credentials. I don't remember the same as f at all I had registered 2 years ago. Neither there is any forgot user ID & forgot PW links to reset the same.
2. Not able to reset to factory reset status. Tried pressing factory reset button with a pin. Not sure if it needs a long press etc.
help appreciated from any experts.
thanks,
raj
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello sankeertana
    You will need to hold the reset button for 10 + seconds.
    DarrenM
