Orbi WiFi 7 RBE973
Reply
How to update the firmware of my Ex7300 extender ?
ammie915
Follower
My new wifi range extender which is EX7300 is having all four solid green lights on it which means it is configured but still I keep on loosing internet on it which is very annoying to me . I was told to update the firmware on it I tried to get on http://www.mywifiext.net or http://www.mywifiextnett.net but got no success in it please help me with the same
Model: EX7300|AC2200 Nighthawk X4 Wall-plug Range Extender
Message 1 of 6
DarrenM
Sr. NETGEAR Moderator
Re: How to update the firmware of my Ex7300 extender ?
try connecting to 192.168.1.250 and that should prompt the extenders login.
DarrenM
Message 2 of 6
DJ_Shave
Attempting to check the firmware in my extender; EX7300 – AC2200 Nighthawk X4 WiFi Range Extender / Serial # 4FM4685E01A6F and cannot access the device.
Tried the suggested address (192.168.1.250) ... getting 403 Forbidden. Had also tried the Netgear directions ( www.mywifiext.net etc ) without success / response "You are not connected to your extender's WiFi network"
Am connected to the Extender as directed but with no luck.
What's next?
Thanks!
Model: EX3700|N600 WiFi Range Extender
Message 3 of 6
DJ_Shave
ps: the above note is from my desktop server (Dell Inspiron, Win10 etc) ... access to the extender using my laptop (Chromebook) succeeded
Message 4 of 6
DarrenM
Are you able to log into your router and find your attached devices page and find out what the IP address of the extender is?
DarrenM
Message 5 of 6
DJ_Shave
Thanksm but no
As I said previously ("Attempting to check the firmware in my extender; EX7300 – AC2200 Nighthawk X4 WiFi Range Extender / Serial # 4FM4685E01A6F and cannot access the device. Tried the suggested address (192.168.1.250) ... getting 403 Forbidden. Had also tried the Netgear directions ( www.mywifiext.net etc ) without success / response "You are not connected to your extender's WiFi network"
ps: the above note is from my desktop server (Dell Inspiron, Win10 etc) ... access to the extender using my laptop (Chromebook) succeeded") and I now have no further problems
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 4574 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
