ethan_marcus
Jun 17, 2016Follower
Internet Connected But Wifi won't turn green or show up on computer on NetGear Trek PR2000
Hi, I just got a netgear trek PR2000 travel router. After finishing the setup for the router I went out for lunch and disconnected the router. Coming back the routers wifi light would not turn green and the computer wasnt seeing a nework(I was on wireless). I tried reseting it but it wont work. Please help!
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello ethan
Have you tried to factory reset the device by holding down the reset button for 10 seconds? After this you should be able to go through the setup again.
DarrenM
