Retired_Member
Jul 10, 2018LED blinking Continuously blinking White
I have this extender for about 2 months and it was working fine. Now all leds on the front are blinking white and also the led on the back (power) is blinking red. Tried to reset, but that didn't work. After that i tried to put it back in factory default, but that also did'nt work.
I can't acces the repeater (wired or wifi). Can somebody tell me what is wrong?
- DarrenMSr. NETGEAR Moderator
You may need to contact support could be a hardware issue.
https://www.netgear.com/support/contact.aspx
DarrenM
- kohpAspirant
had the exact same issue. and when I called in, after being on hold for more than 40min, associate tells me they system is down and should call tomorrow.
Netgear customer service and warranty is just as trash as their device!
I'm having the same issue. All LEDs on the front are blinking white and the power LED on the back is blinking red. Nothing changes by cycling power or pressing the factory reset button. I registered the product, but there is no way to contact support team for help in getting a hardware replacement.
There is a way on my.netgear.com. Step-by-step is below. Clicking on "Replace my defective product" should work too.
