Caesar1948's avatar
Caesar1948
Link rate LEDs quit working
I walked into my home office this morning and found my Apple Airport Time Capsule's ready light was blinking amber. It's connected by Ethernet cable to my EX6200 Range Extender. The link rate LEDs on the EX6200—both of them—are out, but the Device to Extender light is green, as it should be. This setup had been working just fine until this morning—even as late as late last night.
My computer can get its signal from my base router in my living room, but my backup device needs the hard wire connection. I hope someone can help me fix the problem. I updated the firmware about two weeks ago, and everything was in working order till this morning.
  • Later in the day, I remembered to try unplugging the range extender. Did that, left it for a couple of hours, then plugged it in again. Now my Time Machine backup is working again, green light and all, but the Link Rate LEDs on the extender are still out. Not green or red ... just black. I've checked my WiFi status, and I still do not see the EXT connections available—just "Netgear_EXT" as an open connection (no padlock showing). What's going on?
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Caesar1948,
      Welcome to the community!
      It looks like the extender is on its default settings. Have you tried reconfiguring it as an Access Point?
      Dexter
      Community Team
      • Caesar1948's avatar
        Caesar1948
        Hello, Dexter, and thank you for replying. This device has worked almost flawlessly just as it was for about three years, maybe longer. All of a sudden it went off track. Just a few days ago, my laptop (MacBook Pro) connected to the Internet via this range extender. As of this morning, I'm using the signal from my Xfinity X1 router two rooms away. Why? I don't have a clue.
        To answer your question, no, I have never configured the device as an access point. To be honest, I can't claim to understand the difference. I hope you can help me understand. Anyway, how do I configure it as an access point when I can't get into its dashboard? I tried to enter the dashboard this morning, but it reported that it could not access the device. That makes sense, given that the LEDs are both turned off. I'll appreciate your help.
