× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Mesh with powerline?
randydeb
Hi,
I have been using a nighthawk mesh for over a year now with RAX50 router and 2x EAX20 extenders.
The distance of the extenders are bit to much to have good speed.
My internet speed (speed test on router) is a stable 400-450 mbps /25-30 mbps
Speed test on the extenders got 150-200 mbps download.
On my wifi devices close the the extenders download speeds never get above 50mbps.
The 5 Ghz signal on extenders also red most of time, so 5 ghz wifi not usable.
I can't get the extenders closer to the router, so is it possible to connect the extenders with powerlines to the router to make the speed faster on them?
Kind regards
Message 1 of 3
Guru
Re: Mesh with powerline?
1. there isn't powerline based mesh extenders from netgear
2. you could use a powerline adapter or moca adapter to connect the extenders and then just put them in access point mode
Current setup: CM2000-> RBE973S-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 3
randydeb
I have been looking at the Powerline 2000 extender so i can use devices on LAN instead of WIFI.
Want to keep the current mesh setup for the mobile devices, but use powerline for PC's who required better connection.
The EAX20 is on my desk, so i can use the 4 LAN ports as a switch or should i put a separated switch connector to the powerline / pc's?
Kind regards,
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 267 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
