strakerc's avatar
strakerc
Multiple EAX80s - Fastlane to Prevent Connection Issues
Hi there,
There are a lot of threads about using multiple EAX80s to make a mesh network in a large home, and all seem to say "don't do that! They'll connect to themselves, that's the problem!" But if you use Fastlane, you can configure your EAX80 extenders to only connect to 2.4 GHz bands and output 5 GHz bands. Boom, now they can't connect to each other.
However, I still am struggling with setup for multiple EAX80s. I have tried customer support, and they just tell me to spend more money on Orbi. No thanks.
I'd *love* to get a multiple EAX80 setup and working and then share how to do this with everyone. If anyone has had success with this, please share! I think the issue may be with the router not assigning them different IP addresses, thinking they are the same device; I have not seen two such devices show up in my router settings yet (also a Nighthawk router).
See some details here (but where no response has been made): https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/RAX120-with-3-x-EAX80-mesh-extenders-HELP/m-p/1983644#M43108
  • See attached screenshot of only one device despite two on the network. After turning the second one off for a while, it is now defaulting back to 192.168.1.250 IP address, while the other is stable at 192.168.1.9 (as can be seen in the screenshot).
    • plemans's avatar
      Why don't you just set one of them with their own unique ssid?
      • strakerc's avatar
        strakerc
        Why should I have to do that? And why would that help with connectivity to the main router?
  • I suddenly couldn't login to my community 2 days in the past. My different devices inclusive of roommates join best. About an hour ago my internet commenced running all of the sudden as you can read.
