× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
My AC3000 Nighthawk X6S Tri Band WiFi Mesh Extender goes down
philspo
Hi
My AC 3000 Nighthawk X6S model EX8000 keeps shutting down.
It works perfectly for several hours and then disapears from the network and the white leds on the front are off.
Its annoying because I have a Synology NAS attached to it via ethernet and, of course, when the extender is off, I can't reach the NAS neither via internet nor on the LAN.
I have to press the on/off button to switch it off and then on again. Then it works again properly for some hours or even days and after that the problem occurs again.
Has anyone had a similar problem and knows how to fix it ?
Thanks for your help.
Model: EX8000|AC3000 Nighthawk X6S Tri Band WiFi Mesh Extender
Message 1 of 5
Accepted Solutions
philspo
Re: My AC3000 Nighthawk X6S Tri Band WiFi Mesh Extender goes down
Hi,
Thank you very much for your input.
I will try  your suggestions and maybe install a UPS as well.
The problem didn't occur again these last days.
Thanks again
Message 5 of 5
All Replies
Guru
What firmware version is on it?
Did this just start?
Is it a new device?
Message 2 of 5
philspo
Hi
Thanks for the answer.
The firmware is the latest available (can't remember the number ; I'm not home right now)
I think the problem is present since the beginning. I bought the divice last july.
I live in the country. There are regularly some brief power cut-offs here (for a fraction of a second). Could it be the reason ?
I'm not sure about that, but if yes, is there a way to make the device restart automatically after a cut-off ?
Thanks again
Philippe
Message 3 of 5
Guru
2 things you can try.
1. you can try downgrading the firmware a version to check if its a firmware issue.
2. you could try a different power supply. Maybe its crapping out under load at a certain point. If you have a different device with a matching power supply (exact same voltage/polarity and at least the same amperage) you could try it.
Message 4 of 5
philspo
Hi,
Thanks again
Message 5 of 5
Discussion stats
  • 4 replies
  • 702 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
