Limon12's avatar
Limon12
Follower
Jan 29, 2021
My Netgear nighthawk x4 wifi range extender is becoming weaker
Hello everyone,,
4 months ago I have purchased a wifi range extender Netgear Nighthawk x4 dual band. I have plugged my pc ethernet cable directly into the extender. My internet speed at my router is always 100mbps and nighthawk used to slice the speed in half to 50mbps, which I understand because that's how extenders work. But now my pc is only getting 30-35mbps through the extender, even though my router is still outputing 100mbps. Does anyone know why nighthawk has suddenly dropped speeds so much? I have also changed some things in the registry editor of my pc but those shouldn't affect the extender right? I have tested speeds through nighthawk with my phone as well to confirm that my pc ethernet adapter was working fine.
1 Reply
  • plemans's avatar
    What actual extender model is it?
    What router is it connected to?
    What firmware is on the extender?
    Are you using fastlane on the extender?
