- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
N300 EX2700 Connect with Web Browser Setup
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello!
I have a N300 Wifi Range Extender Model EX2700.
I connected to the _EXT Wifi Network but when I launch a web browser and enter www.mywifiet.net I am told I am not connected to my extender's wifi network. What has gone wrong?
I did not have to put in a security key to connect to the _EXT Wifi Network, instead I got information from the router. When I previously (after factory reset) tried to connect to the _EXT Wifi Network in another room from the router I was asked to put in the security key which did not work. I initially tried through WPS which did not work.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: N300 EX2700 Connect with Web Browser Setup
Try doing it this way.
connect a pc/laptop to the extenders ethernet port. Disable wifi on the device you connect to it. reason why is the ethernet port won't have a connection and the pc/laptop can default back to the wireless.
then try the mywifiext . net
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for your advice. I still get the message that I am not connected to my extender's WiFi network. I connected the router and extender through WPS. Could that be the problem?
Thanks again!
Charlotte
- Mark as New
- Bookmark
- Subscribe
- Permalink
It sure could be the wps. Try factory resetting the extender and reinstalling using the installation wizard and not wps.
