fzaheer
Jan 11, 2018Follower
N300 Travel Router connection problems
Hi,
The extender was working fine, however suddenly i have noticed i can no longer see its wifi. Tried resetting it, but not sure even if it is getting reset. Cannot see the wifi or connect to i through wire. Cannot see the router login screen. Not really sure what has happened.
Appreciate any pointers, or is this the expected quality of the product (was in use for around 6 months.
Regards
Faisal
1 Reply
- DarrenMSr. NETGEAR Moderator
You may want to contact support if you no longer can access the system even after factory resets.
http://www.netgear.com/support/contact.aspx
DarrenM
