JCJD's avatar
JCJD
Follower
May 22, 2017
N300(WN3100RP) Won't Boot
Hi,
My N300 won't boot and the Power LED is always solid amber.
I tried to reset to factory settings but that doesn't seem to solve the problem.
Please help me.
Best Regards.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello JCJD
    It sounds like the unit has bricked. Make sure you hold the reset button down for 10+ seconds and if its still not working you may want to contact support if the unit is still under warranty.
    http://www.netgear.com/support/contact.aspx
    DarrenM
