Nancywb70's avatar
Nancywb70
Need recommendation for new WiFi extender
Hi - We need to upgrade our WiFi extender.  We currently have the WN300 RP but it is not working well with our ADT cameras which seem to be falling out of range.  We have an Orbi RBR50.  Which WiFi extender would be compatible and give us maximum range?  Thanks.
  • plemans's avatar
    If you've already got an orbi router (and the rbr50 is a solid one at that) I'd add satellites to it.
    You can use the RBR20, RBW30, RBS40, RBS40V, RBS50, RBS50Y.
    the  EX7500, EX7700, EX8000 would all also work but wouldn't be "controlled" by the orbi router like the full orbi satellites.
    • Nancywb70's avatar
      Nancywb70
      Sorry.  I think the extender is for our ADT system wich is an Arris Touchstone CM8200.  That is what we need the extender for.
      • plemans's avatar
        the Touchstone cm8200 is a modem only. What router do you have?
