KBDB's avatar
KBDB
Follower
Sep 04, 2024
Need wifi extenders
Hello.
Just purchased the AX5400 (RAX54S) and unfortunately the signal is very weak on the upper levels of the house.
Are there any wifi extenders that will work with this router? I'd really rather not have to purchase a mesh system with a new router.
The router is located on an open shelf with the modem, and 3 feet from the TV, with no other electronics near it.
  • FURRYe38's avatar
    Check out EAX series extenders. EX7700 or EX8000 would do in a pinch as well though those are not AX mode supporting. I just got a EAX80 from shopgoodwill for cheep.
  • plemans's avatar
    Any of the EAX lines would work and be AX devices.
    You can see them here:
    https://www.netgear.com/home/wifi/range-extenders/
    The eax line currently has the EAX12, EAX15, EAX20, and the EAX80
    If you're only needing one, they're a great option. If you're needing more than 1, then I'd be looking at returning the router and looking at a mesh system.
