burt35
Dec 29, 2016Aspirant
Netgear EX6150 v2 disconnection
hi recently purchased this wifi extender and have connected it to my dgnd3700 router as an access point but the connection seems to disconnect every 10 mins or so then reconnect again, i have latest firmware and have reset the device twice. any clues?
- DarrenMSr. NETGEAR Moderator
Hello burt35
Have you tried to change the ethernet cable that you are using? or is it connected via wireless if so you may want to change the wireless channel on your router to see if you can get a better connection.
DarrenM
- burt35Aspirant
hi there darren i have now stopped using it as an access point and im using it as a wifi extender which seems to have solved the issue strangely, i have tried different ethernet cables before hand still the same. thanks for your time and help.
