rgeofroy's avatar
rgeofroy
Netgear N300 Range Extender and Netgear LB1120 Broadband Modem
I have just bought a Netgear N300 Wifi Range Extender to help me provide access to my wifi in my home and cannot connect the range extender to the broadband modem connected to an Actiontec router as the broadband modem does not have WPS. I keep getting the message to press the WPS button on my router and there is none. Neither the modem nor the router have a WPS button. At least I believe that is where the problem lies. Can anyone help? Maybe I bought the wrong extender!!
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi rgeofroy,
    I would like to follow up and check if you are still experiencing the issue.
    Dexter
    Community Team
    • rgeofroy's avatar
      rgeofroy
      Thanks for asking. I managed to solve the issue using the Netgear Installation Assistant. It works fine now.
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi rgeofroy,
      Thank you for the update and confirmation. Glad to know you got it working.
      Dexter
      Community Team
