- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk X4S AC2200 triband, finding my Wifi extension on my phone, tablet, computer?
- Mark as New
- Bookmark
- Subscribe
- Permalink
My Nighthawk X4S extender started up perfect just by using the WPS button on the extender and router. The LEDs are ALL blue indicating I have both 2.4 and 5ghz Wifis. When I look on my phone, tablet, or computer UNDER the Wifis avaliable, I do not see any of the Extender Wifis. I only see the 2.4 / 5Ghz Wifi from my Spectrum router Wifi. In my case that is Todd1 (2.4) and Todd2 (5). I do not see any of the extender mesh extensions. How do I fix this issue Please?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
When you setup the EX7500 with wps, if you're running a dual band router, it'll automatically connect to the 5ghz band with one of the radios backhaul. It then sets up the extender in mesh mode (single ssid) for the 2 other bands. So you won't see it as seperate with a regular phone/tablet/pc unless you're running a wifi analyzer app/program.
If you'd like to seperate them out, re-run your setup on the extender but use the smart connection wizard. it gives you more options during setup such as individual ssids/one ssid function.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk X4S AC2200 triband, finding my Wifi extension on my phone, tablet, computer?
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
