Stoic_Brow's avatar
Stoic_Brow
Nighthawk X4S EX7500 - No Internet Connection Issue
I have seen some previous posts about connection issues with the X4S EX7500 and I too am having problems with this Wifi Extender. I have done a FEW factory resets and have had no luck in a consistant reliable connection. My router has an active internet connection yet the EX7500 is unable to distribute any internet access.
I have also tried to downgrade the firmware to a previous, more functional, version with no luck.
Is there a new firmware being release in the near future to deal with this issue?
Is there a process I can follow to successfully install a previous firmware version for now?
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello Stoic_Brow
    1. Does the extender appear as an attached device when you check the router UI?
    2. Are device(s) able to connect to the EX7500? If so, what device(s)?
    ~Christian
    • Stoic_Brow's avatar
      Stoic_Brow
      1) Yes the router has the EX7500 listed as a connected device.
      2) I have a Nvidia Shield TV, a Surface Pro, and a Sony Xperia Z3 connected to the extension network.
      Stoic_Brow
      Christian_R
      The extender cannot even check for firmware on its own because it says it is not connected to the internet, but other devices I have connected to the original network do have an internet connection.
      It is useless in its current state.
