- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk X6S does not list connected devices
- Mark as New
- Bookmark
- Subscribe
- Permalink
Having logged on to my new X6S (set up as an access point with the router and two subsidiary devices connected through cable and a few wirelessly), I try to list the connected devices. I get the "Please wait a moment" popup, but then it stalls. This happen however I connect my laptop. Rebooting the router does not help.
Has anyone else experienced this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk X6S does not list connected devices
I have the same issue, got it today, setup in Access Point Mode.
Tried with Chrome and Edge browsers with the same issue.
The model number,
- Hardware Version: EX8000
- Firmware Version: V1.0.0.102
Is not in the list of models for some reason.
Also it fails to find firmware updates saying no connected to the internet which is not true.
P.S. You still have to unzip the firmware update if you download it. It will accept the zipped file as being an update and then say it is wrong for this model.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes I have tested this myself and made the issue known to the engineers they will resolve this in upcoming firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Seems to be a bit better in new firmware out now...
- Firmware Version: V1.0.0.118
It does however seem to get the list of wired clients wrong, I assumed it would only show devices plugged into the rear ports but it lists all of them...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just tried it again and it no longer works 😞 😞 😞
Pretty pathetic and as the last "update" was November how long will it take before their next attempt?
EDIT: Tried it again and it worked so it seems to be a bit hit or miss...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a new X6S as well - mine also does not show devices. I am however not using it in AP mode. I'm using it as an extender. Though it's 300 ft aaway from the primary router and is handling 3 lan connections and several wifi. (shouldn't it still list devices?) I installed the latest .118 firmware only to find out while doing so that I already have it. So just installed it again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All,
Connected devices must work fine on lastest firmware v1.0.0.118. Extender will list every device which is connected through to its network via any switch or hub wired and wireless too. Let me know if you come across any issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
WEIRD - I've had the router for a month new - and it never has listed everything. Usually nothing, and once in a while 1-2 things.
I just read your message saying 118 DOES DISPLAY ALL. (I have 118) in mine.
So I looked (again - I've done so 50 times with no accurate result) and after reading your post - I see everything and more I didn't even know was connected as the things are closer to the primary router. So what did you do to make it work all of a sudden? I won't believe it until I check next time and everything is shown.
What is the check box to ENABLE ACCESS CONTROL:?
Connected Devices
192.168.1.250 | MySpectrumWiFi39-2G | B0:39:56:8D:0C:7D | B6:39:56:8D:0C:7D 02:0F:B5:8D:0C:7D |
192.168.1.250 | MySpectrumWiFi39-5G | B0:39:56:8D:0C:7E | B6:39:56:8D:0C:7F 02:0F:B5:8D:0C:7D |
192.168.1.85 | GTOCP4_791 | 02:00:00:0 | 02:0F:B5:7 |
192.168.1.84 | aagsolo | B8:27:EB:28 | 02:0F:B5:2E |
192.168.1.100 | DomeSWITCHER | 7C:E1:F | 02:0:27:B3 | 3 | -72dbm | 150Mbps |
192.168.1.17 | <unknown> | 44:2C:05:F | 02:0F: | 3 | -40dbm | 72Mbps |
192.168.1.18 | <unknown> | AC:83:F3:2 | 02:0F:B5: | 3 | -76dbm | 39Mbps |
192.168.1.20 | <unknown> | AC:83:F3: | 2:0F:B5 | 3 | -61dbm | 72Mbps |
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @rojoyinc,
I will wait for you to moniter it. Just to keep you notified, if your device is connected to router's network, it'll not be listed in extender's connected device though this extender is using same SSID as your router. Enable access control is similar to access control on routers where you can block/deny access to any of wireless client by enabling it.
