× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Nighthawk X6S
Lhudson2
Follower
Nighthawk X6S
Can I install my extended laying on its back or side?
Model: EX8000|AC3000 Nighthawk X6S Tri Band WiFi Mesh Extender
Message 1 of 2
Guru
Re: Nighthawk X6S
Can you install it that way? Sure
Will it potentially reduce the lifespan of it? Probably. Its designed with a certain orientation to passively cool it. If you're laying it down/putting it on its side, its potentially impacting how it cools. heat is the death of electronics.
But it might never impact it or cause an issue.
For example, I have a RAX200 thats not designed to be wall mounted. But it is. And I've had it over a year with it running normally and the fan never kicking on.
So its kind of up to you if its worth the risk of a shorter lifespan or not.
Or if you've got a fan/cooler to direct at it, it might not change it at all.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 413 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
