× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
No result after applying settings
tilly2016
Follower
Applied settings for ex2700 with no results after sending..The only response is "Applying your settings.  This may take up to a minute"
Model: EX2700|N300 WiFi Range Extender
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: No result after applying settings
Hello tilly2016
Have you made sure you have no firewall or pop up blocker stopping the changes? also you may want to try a different web browser.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2209 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
