SSCZA's avatar
SSCZA
Orbi RBR50 - "No such file or directory"
I am using an ORBI RBR50 - base and one satellite. Set up and was working great. Reorganized office and moved the base. (actually almost swapping the base and satellite). Connecting to a new network wired into my house. Now with computers using the wifi from the Orbi, I can get to some websites - e.g. google.ca - but others give me "no such file or directory" -- e.g. netgear.com. If I wire directly into the router, I can get to Netgear.com and all the other sites I am trying to reach. Really ties it back to the Orbi. Any ideas?
  • SSCZA's avatar
    SSCZA
    Feb 18, 2018
    Thank you. Every device was impacted.
    I follow the recommendation from another thread to reset my Orbi and set up again. That seems to of done the trick and I’m back up and running again.
    Thanks for following up!
  • Hi SSCZA,
                         Do you experience this on all devices or specific device? Was the same device able to access those websites when connected wired to Orbi router?
    • SSCZA's avatar
      SSCZA
      • jvasanth1984's avatar
        jvasanth1984
        Virtuoso
        Hi SSCZA,
                             Good to know that reset and reconfiguring the device resolved your issue.
