egrani's avatar
egrani
Follower
Oct 04, 2019
Password Reset (mywifiext.net)
Need help resetting the password for https://www.mywifiext.net. Security questions not working and we realize it's case sensitive. Also the password is different from netgear.com for some reason apparently. I need to update the firmware on the device and cannot get past the security questions and there are zero links to try to help. Please help!
  • when i need to login to my netgear network, a message say that a password iis reguired. but when i prees the massage on login page. no login page appers?
    also tryed the nighthawk app. then the massage appers: the app do not suport my synology wifi router.
    also tryed to reset the router and the extender.
    • olympos1625's avatar
      olympos1625
      NETGEAR Employee Retired
      Hi @mbj9610,
      Thank you for reaching out. We are sorry for not being able to get back to you immediately. When you say," when I need to login to my Netgear network, a message says that a password is required" Are you talking about the router or extender? Did you try to re-setup the extender and see if the error still occurs?
      I am looking forward to your response.
      Oliver
      Community Team
