Retired_Member's avatar
Retired_Member
Apr 27, 2020
Router(R6350) Not Working With Switch
My route when connected to my switch will not send data to the switch or my computer plugged into my switch. Connected directly to the router the ethernet works fine but connected to the switch with my computer plugged into the switch it does not send data but still sees the ethernet cable plugged in. Any help or question would be appreciated.
Thank you,
John
  • plemans's avatar
    Have you tried a different switch?
    Or different cabling?
    What firmware is on the router?
    What switch is it?
