- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Router light not on
- Mark as New
- Bookmark
- Subscribe
- Permalink
Router light not on
I reset my extender following the manual's directions and all lights are on but the Router and Device lights. When I choose to connect to the EXT wireless, my computer says it's connected but then the internet doesn't load. It has worked in the past so I'm not sure what went wrong and the restart didn't work.
Help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Router light not on
Hello personal515
Have you tried to connect the extender using WPS to the router?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have similar issue. Recently got a new modem from sky so network name and key changed. WiFi extender coming up on device (SAMSUNG TABLET)with new network name but then requests password. When I enter the correct network password it comes back with password incorrect. The power and wPS lights are solid green but the router light is not. The extender is plugged in right next to the router. Can you help or am I simply going to take a baseball bat to the thing ?! I TRIED wps connection. Also tried reset to factory settings. Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Fatmrsgeorge
Have you tried to forget the network on your tablet then reconnect? also if the extender is not connecting to the new router make sure the security on the router is set to WPA2. When doing a factory reset on the extender hold down the button for 10 seconds then try setup again.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just did a factory reset and then connected it again from scratch using the second option (not the WPS way) - and now it works! So I would suggest trying that...
