majinboose's avatar
majinboose
WN2000RPT V3 problems
My WN2000RPT V3 lost connection on Monday when my Internet went down and I can't get it back up. The one green light is flashing. I tried resetting new firmware etc.. still does the same thing.
I was wondering if this was part of the DNS issue that wass happening? Also is there a way to get the latedt firmware/driver that is not a disk image?
any ideas?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Have you tried a full factory reset by holding the reset button for 10+ seconds then setting the extender back up?
    DarrenM
    • majinboose's avatar
      majinboose
      Yes, I have it still just has the blinking green light. I think the router is just old a fried. I even tried hiioking it up to the modem with a eithernet cable and nothing.
