SunnyJim
Oct 21, 2016Follower
WN2500RP link rate lights are 'out'. Power light, wireless device to extender and WPS are all green.
Has the unit failed? I have tried to turn off/on, and tried to reset to factory settings. both unsuccesful.The link rate lights will not light up. the LAN ports also blacked out. Thoughts?
Thank you
- DarrenMSr. NETGEAR Moderator
Hello SunnyJIm
If you are getting no lights at all then it does sound like the unit has failed.
DarrenM
- jsaborAspirant
My home network is connected by N600 model WNDR3400v3, we are unable to print from Apple ipad which we recently added. We purchased the N600 Wifi range extender model WN2500RP in order to be able to print from the Apple ipad located in another room. We need instructions how to connect the extender and where to locate it. Thank you, J.R. Sabor, ESQ
Hello jsabor
You may want to look at this.http://www.downloads.netgear.com/files/GDC/WN2500RPV2/WN2500RPv2_QSG_EN.pdf
DarrenM
