venkats
Feb 03, 2021Aspirant
WN3500RP - How to disable AP isolation configuration
Hi,
I have used WN35000RP to extend my Guest Wifi network. I could connect internet and surf with devices. But when I try to use Chromecast and cast the video, I am unable to connect.
As the chromecast help suggest me to disable the AP Isolation in the extender. But I couldn't find the configuration in NETGEAR gene configuration. I use tp-link Archer VR 1600v router and disabled the AP Isolation configuration.
Appreciate your help to resolve this issue.
Thanks & Regards,
Venkat
