ianhill090776
May 22, 2011Follower
WNDR3400 can't find harddrive via USB
Hello all,
I'm running...
WNDR3400 + Transcend storejet 25f 500gb external hard drive + MacBook Pro running Mac OS X v. 10.6.6.
The hard drive is plugged into the USB port on the Router, and I can see it when I log into routerlogin. It's showing at \\readyshare\USB_Storage, Network Connection \\readyshare. I have HTTP enabled, but not HTTP via Internet, FTP or FTP ia Internet.
I want to access to the hard drive via Go to Server or Go to Folder in my MacBook Pro. I've tried U:\ in Go to Folder and all the locations listed in routerlogin via Go to Server, and the MacBook says it can't find the server/folder.
Thoughts?
Your help is much appreciated!
I'm running...
Thoughts?
- Jack_AspirantNot personal familiar with this device, but most external harddrives must be formatted to FAT32 in order to work with a router's USB port. HTH
- sccarlsoAspirantTo connect to a Windows file share on a Mac you need to use the "Connect to Server" option and put in
smb:\\readyshare
or substitute the IP of the router for the name
smb:\\192.168.1.1\
Mac's running Lion are much more friendly to Windows shares, so if you're using Lion it may just show up in your Network list.
Good luck! - stevewoolNovicecan't find printer via USB
hardrive works but when I attach my HPlaserjet 1000 it does not show up
help please
